I'd also say it unusual to see significant heat but a slight warming up i would say would be normal. Is this a functioning design?Is it normal for UC3843 ic in SMPS circuit to slightly heat up while on working operation within some seconds without load.
timing components 82k and 2A472j
At the gate I have 22R and 10k pull down Resistor'
I attached the schematic here , the timing is components are 8.2k and 472pf
The VCC is giving me 15vdc instead of 8. v that is heating up i guess. VREF is 5v which is normal in this design. I want to know what happen i am seeing 15v at PIN 7No its not. What Vcc are you giving it?
Do you have load on the Vref pin.
What timing components do you use.
What is connected to the gate drive pin?
I tested the Fet's and is working fineIf the mosfet gate is damaged / leaky then the gate drive currents from that pin may be higher and cause the chip to heat up.
At 100kHz, warm to the touch is not uncommon.
As above if you go over 34V of the internal zener from the bias supply - you will cook the device - also higher than 16V Vcc will heat the internal gate drivers - and you can damage the mosfet you are trying to drive ....
yes, the Auxilary VCC is suppose to be 12v but 15v is thereI'd also say it unusual to see significant heat but a slight warming up i would say would be normal. Is this a functioning design?
C2 Looks unusually placed, its function isn't too obvious to me. Its normal to have a small RC on the current sense which is your C29 & R7 but C2 i struggle to identify its purpose.
I'm not familar with the UC3843 but I also find the shorting of the FB to ground quite an interesting idea i've not seen before. This will pull the error amplifier 5V making the COMP pin a fixed current source but eliminates the error amplifier functionaly in the IC to instead be created from the TL431 & opto.
T6 looks to be providing an Auxilary VCC via the 5R1 resistor obviously the higher the voltage on this the more heat you'll be disipating.
Ok, so the the circuit is operating but your vcc is high? Is that correct? This points me back to the voltage of you auxiliary supply once the supply is running which powers the Vcc via R6. Is the output voltage correct and also are you sure Vcc is 12v by design? whats the transformer turns ratio. Given your saying its 15V if the output is 15v i would expect A 1:1 ratio between the windings for a 15v vccyes, the Auxilary VCC is suppose to be 12v but 15v is there
