[AVR] UART with atmega128 question
Justin Wenger
Newbie level 5
Newbie level 5
guys, I want to make a UART code that prints '........' permanently and when I Interrupt(with INT0), it prints 'ppppp' instead, and when I interrupt again(with INT1), it prints '.....'again.
But the interrupt part isn't working.. The code works well printing '....' but even if I press INT0, nothing changes and it keeps printing '...'
if someone knows what the problem with this code is, please share your wisdom
#define F_CPU 16000000
#include <avr/io.h>
#include <avr/interrupt.h>
void uart0_init(void);
int Putchar(char message);
int x=0;
int main(void)
uart0_init();
while(1)
if(x==0)
Putchar('.');
if(x==1)
Putchar('p');
int interrupt(void)
EICRA = 0x0F; // Rising Edge detection
EIMSK = 0x03; // Set INT0 & INT1
SREG |= 0x80; // Global Interrupt Enable
while(1)
ISR(INT0_vect)
x++;
ISR(INT1_vect)
x--;
void uart0_init(void) {
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C = 0x06;
UBRR0L = 0x67; //set baud rate lo
UBRR0H = 0x00; //set baud rate hi
UCSR0B = 0x18;
int Putchar(char message) {// Putchar "P" cVde
while (((UCSR0A>>UDRE0)&0x01) == 0) ; // UDRE, data register empty
UDR0 = message;
return 0;
In the code posted, the function interrupt() is never called. It looks like this function defines and enables the interrupts. The function has a while(1) statement that would prevent it from returning if it was called.
Didn't go through the whole code...
But variables that are modified in the interrupt and used in the main loop need to be declared as "volatile".
What happens when "x < 0" or "x > 1" ?
Klaus
I do not see where you executed attachInterrupt() ?
Regards, Dana.
Thank you so much guys!! It works!!
