Uart simmulation on proteus using atmega 32
belal elkady
Newbie level 6
Newbie level 6
EgYpT
it's the first code in UART so i'm trying to simulate it and i use the virtual terminal on proteus
but nothing appear i don't know why ??
the code :
* Uart_Driver.c
* Created: 7/29/2013 4:33:00 PM
* Author: Belak Magdy
#include <avr/io.h>
void UARTinit();
void UARTsender(char data);
char UARTreceiver();
void UARTinit(){
UBRRH=0X03; // 1200 bps & 16MHZ clock frequency
UBRRL=0X41;
UCSRB|=(1<<RXEN)|(1<<TXEN);
UCSRC|=(1<<URSEL)|(3<<UCSZ0);
void UARTsender(char data){
while(!(UCSRA & (1<<UDRE))) {
UDR = data ;
char UARTreceiver(){
while (!(UCSRA & (1<<RXC))){
return UDR;
that's very simple app:
#include <avr/io.h>
#include <stdio.h>
void main (){
UARTinit();
while(1){
UARTsender("b");
UARTreceiver();
did you select the baudrate settings in virtual terminal and frequency in Chip??
then it must be the problem of
Code C - [expand]
while(!(UCSRA & (1<<UDRE))) {}
try to take this commanded if still not works check the config, then there is no uart in the library device..
Code C - [expand]
yes, i did and i don't find any problem in the code . please take a look at the simulation
Hi belal elkady
I haven't checked your baud rate and other settings yet But your UARTsender function expects a char and you are passing it a string
try changing
Code C - [expand]
UARTsender("b");
to
Code C - [expand]
UARTsender('b');
Hi belal elkady
try changing
Code C - [expand]
UARTsender("b");
to
Code C - [expand]
UARTsender('b');
How did I missed it, It will show an compilation error... :smile:
I changed it but it still not working :(
i use a crystal of 16mhz and the baud rate is 1200 bps
