uA741 vs LM324 which is better op amp
Aisha.Raj
Newbie level 3
Newbie level 3
Can someone pls guide me as to which is a practically better op amp , the uA741 or the LM 324 when it comes to using an op amp in a pulse generator circuit ( to generate square pulses of width varying from 0.1ms to 1s and varying duty-cycle from 25% to 75 % ) ....??? What could be the major concern issues when i am choosing the op amps ....?? I mean when i used either of them i was not able to pin point major differences in the waveforms...
I have attached the circuit below...
There is a thread which have dealt with your question in this forum search for it.
But for me LM324 is better both in cost and features and don't forget that it has four op amps in it.
In your application LM324 will be good, as it uses low power and hence noise is very low as compared to ua741, which uses around 15v VCC to run. So i strongly recommend lm324 in your application.
The 741 opamp and the LM324 quad opamp are both very old with poor specs today.
They operate slowly so the narrow output "pulses" will be like ramps.
Hey,
I recently did a project where I needed to generate a square wave. I won't tell you which is better, but I can tell you what I looked for when choosing my op amps. Some things to consider:
1) Input offset voltage. How much DC offset can your pulse tolerate? High power op amps tend to have higher offsets, at least from my experience. Related to that...
2) Input current bias! Same kind of deal. And related to that...
3) Input impedance! If it's too low, you're really not amplifying what you want.
4) Slew rate, measured in volts/microsecond. It's basically your maximum slope for your waveform. This probably isn't super important because you're not going into frequency ranges where slew rate might have an effect.
5) Gain bandwidth. Again, probably not a concern with kHz applications, but something useful to note.
6) Output impedance. As low as possible! Related to that...
7) Output current. Many opamps don't really have a high output current, so if you plan on driving something, check the output current first! The first op amp I got for my project only could supply ~5mA, but I wanted to drive something that needed about 20mA, so I had to switch my op amp.
8) Number of opamps/package. That's more of a cost and area thing.
9) Supply voltage/current. Do you have access to a double supply, and how large? And how much current can you afford to draw? Is this powered by battery or plugged into a wall? Remember, your supply voltage is also related to your maximum amplitude!
Anyway, there were just a few points I considered for my project. A lot of these may not have an effect on your project, but in general they were points of information that I thought were useful in mine. I hope this helps you pick out the proper op amp!
Hi
Friend
The basic difference in lm324 and 741 is given below.
In lm324 the Vcc is used also as V++ of the com-perter and ground as v--.
While in 741 there is separate V++ and V-- which are lags # 7 and 4 respectively.
