J.b.
Newbie level 2
741 voltage follower
Dear all,
I tried to use the 741 as a voltage follower. The IC should give an output that can vary between 0 and 2.4V. I noticed, however, that the IC always has a minimum output of 1.92V even when the input voltage is lower. Is this because I used 0V on the V- and 12V on the V+. If so, can sombody advice me a suitable opamp that can work with ground and 5 or 12V.
Thanks a lot
Dear all,
Thanks a lot
