~analoger~
Banned
Hello,
This is my first post here.
I'm trying to design a circuit that has a capacitance/resistance controlled oscillator. I want to add a frequency option control panel from which a frequency is selected using push buttons like the ones used in a calculator. By design the circuit will not use a variable capacitor/resistor, I will hard-wire a fixed array of both Cs and Rs.
First question, to connect a specific C or R to obtain the desired frequency the electro-mechanical relay is not an option, so here I'm probably looking for semiconductor switching devices. However as I'm reading about transistors they let current flow so they are not really isolated from the main circuit, like traditional relays. Is there any other equivalent to mechanical relays?
Second question, what circuit element should I use for push-buttons, like the ones in a calculator?
So when the switch is released it turns on/off something and state is preserved until another trigger takes place.
Help appreciated.
Help appreciated.
