TX r Engineering
Dummyeng
Member level 5
Member level 5
Hi
you have a lot of rx but only 2 tx
the modulation is pm
the freq is 800M
the link is for data gathering for example change in current temp voltage and the BW is 2Mhz(it seems)
you didnt know anything about channel coding RX tx and so on
the manufacture where produce it closed so you cant get any info
this link has GUI and i can see the change when they happen
is it possible to build tx module?
Use DVBT stick and SDR tool to analyze and decode the modulation. If you want actual help, send substantial information.
Thx
For example i use that and see signals
So
I should use signal analizer for example sdr to recognize my signals then for each and i should connect rx output to another port to recognize my data
So for each change in my adc i should gather alot of data
Is it correct?
Pls ask ur question
