Two-wire Transmitter application and isolation
Candy8866
Member level 2
Member level 2
shenzhen
two wire transmitter design
Two-wire Transmitter is provided through the signal line drive power of the transmitter,the transmitter can be used to save the power cord.Two-Wire Transmitter differential pressure transmitter is first used.Differential pressure transmitter generally scattered distribution in large factories.The use of two wires transmitter,significantly reducing construction costs.Two-wire and 4-wires transmitters difference is that it can greatly save the cost of the power cord.
Now we commend a two-wire isolated transmitter chip.
The chip can be used to simplify the isolation circuit of Two-wire Transmitter,greatly reduce the isolation cost,in making the overall system reliability to improve the circumstances of low-cost lower and lower.[/img]
