Two-Stage OpAmp with pmos
amir_rch
Junior Member level 3
Hello friends
I need to have a high-gain amplifier circuit with pmos input. Who can help me?
Hi
You can try with folded cascode opamp. It will give you a better specification.
Yes as "@Analog_Domain" mentioned, you can use folded cascode op-amp but if swing is not a issue and you want to dissipate very less power (power dissipation is your concerned) then go for telescopic cascode .
For high gain you can also use gain boosting in your op-amp with common mode feedback to insure your constant output voltage.
-Rahul
"Take a step ahead and things will start happening"
