[AVR] Two serial ports with atmega 8 / 16 /32 is it possible to use
ark5230
Advanced Member level 3
India
Is it possible to implement two serial ports on Atmega 8/ 16/ 32 etc.
How to do that.
Is the concept of software modem of any use in such situation.
Any hint or link please.
You can use software uart for this purpose, multiplexer can also work in such situation.
xpress_embedo
Would you kindly advise as to how to implement the same.
Which one is easier.
Well i don't know which one is better, and i can't comment about the easiest method.
Here are few links
http://www.atmel.com/images/doc0941.pdf
http://github.com/blalor/avr-softuart
http://www.avrfreaks.net/forum/software-serial-uart?page=all
If you use mikroC for AVR compiler then it has in built libraries for this purpose.
Few years back i used Software UART for PIC18f4550 micro-controller and that works for me in that project.
But i had used Software UART Transmission first and then Switch to Software Reception Mode.
Yes,
Thanks, it has info on what I am trying to do.
I will be back in case of difficulty.
