Two questions on Parallel Ports
neoaspilet11
Full Member level 5
Full Member level 5
Cebu, Philippines
Parallel Port Questions
1.) Are all parallel ports have their last three bits of the status register permanently all 0's?
2.) If I am reading 1's on these bits, the last three bits of the status register, is there a way of making these bits to zero? (Aside from explicitly programming it)
Thanks
You should not make any assumptions about the state of bit syou are not using. The status register is read only. You should mask the bits you are nto using.
Re: Parallel Port Questions
Hi heoaspilet11
Look this home page, is in portuguese and have many things about parallel ports, it's very good..
https://www.rogercom.com
Elson
Brasil
