two questions need help - ideal switch, ptat bandgap
lhlbluesky
Banned
Advanced Member level 2
china
first, if i use a ideal switch (switch of analoglib) to simulate something, and it has 4 terminals N+\N-\NC+\NC- , then how to simulate a ideal swith use it if i want to use a pulse to control its on\off,when vclk=vdd,it is on,when vclk=0,it is off? i use N+ and N- for input and output,NC- is grounded,NC+ connects a pulse(vpulse of analoglib),but it doesn't work.pls tell me what should i do to make it work well.
second,i have a ptat bandgap(with an opamp in it),then i want to get the ac gain and PM of the opamp,then what should i do,can anyone give me the simulation circuit or some advice,pls?
thaks all for reply.
Re: two questions need help
NC- should not connect to ground. It should connect -vclk
For the bandgap you must open the loop that the opamp is creating. Probably a good spot is at one of its inputs
i use NC- connected to -vclk,but it doesn't work also,then if vdd=3.3v, and what 's the value of open voltage and closed voltage in switch parameters?
and how to make the switch work well?
Define a model of the switch and set its parameters.
but how to define a model of switch,can you say more clearly,pls?
Goto the manual and help texts in your software...
