neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
DDS is as stable as the source, its direct frequency division through a phase increment latch, plus a digital to analog conversion in cases where a sine wave output is desired.
Two DDS dividers running from the same source would track exactly.
If the obtainable DDS frequency increments were 1 Hz, you could generate two frequencies 1Hz apart very easily.
Is this also the case with microcontrollers when used as DDS? (i.e microcontroller produces a square wave by switching on and off a pin).
If so, two microcontrollers could be driven by the same external oscillator, or the same microcontroller can output two outputs with different division ratio and so different frequencies.
Will these frequencies exactly track each other?
