engr_joni_ee
Advanced Member level 3
I have signal which comes from an OpAmp which has done amplification. I would like to add an offset to this signal which means I need to use a summing amplifier whose one input should be amplified signal and the other input has to be the offset signal.
How is the impedance related in this case ? when the output of one OpAmp has to go to the other OpAmp ? Do I need to terminate the output of first OpAmp with 50 Ohm and then connect to the second OpAmp ?
