Two frequency widebeam riometer, any useful sources?
franken35
Newbie level 6
Newbie level 6
Hi, my MSc project work is designing and building two frequency widebeam riometer. I have never worked in this area. Do you know any useful sources or even previous designs. I have found just the first riometer designs (1951-53), but obviously I need something much more new then that. Thanks in advance
Analogue riometer design
Hi Franken 35,
did you checked this all pls?:
Googles resultats: ~ 926 for " two frequency wide beam riometer." (0.30 sec) ...
K.
Added after 6 minutes:
~287 for "two frequency wide beam riometer realisation". (0,12sec)
An imaging riometer for ionospheric studies - Electronics ...ieeexplore.ieee.org/iel1/2219/10016/00475198.pdf?arnumber=475198
Perturbations in EISCAT electron densities visualised by ..: An important feature is that for the two time periods of January 2003 we can ... an imaging riometer consists of a steerable beam realised by appropriate phasing of an ... With a collision frequency profile we can thus calculate ionospheric ... The riometer before 18:00 is based on the wide-beam riometer at Abisko, ... "linkinghub.elseviere.com/retrieve/pii/S0273117706000494"
Re: Analogue riometer design
Hello karesz,
Thank you for information. I do admire your enthusiasm of google. That is almost the first resourse I tried. However I found a lot of information on measurements, physics and imaging riometers. But not much on widebeam riometers designs in particularly.
The link above I cannot access for some reason.
Regards,
Frank
Hallo Frank,
Im not a super fun from it, but is good to use:)...
Im sorry, I dont tell it for you; on what a link I become these item:-(...
The sentence "The riometer before 18:00 is based on the wide-beam riometer at Abisko" was their title, but my PC, at home, can not find some similar with it, may be in the firm on monday...
If you cant find some practicable infos, you must in short time & more times repeat your searches; the search engines will collect more data over frequently searched subjects:)
K.
Added after 52 minutes:
Yet I have it; you must search for: "Perturbations in EISCAT electron densities visualised by ..."
https://www.google.ch/search?hl=de&...isualised+by+...++-&btnG=Suche&meta=&aq=f&oq= -
For References:
LJS Riometers: a personal history 1971-2008.: www.lajollasciences.com/LJShistory.html
www.riometer.org
Imaging Riometer Information: www.ips.gov.au/World_Data_Centre/1/6/2
Riometer, www.ips.gov.au/World_Data_Centre/1/8
Riometry Publications: www.dcs.lancs.ac.uk/pub/cgi-bin/sea...=date&order_by_dir=desc&search_title=Riometry Publications
Near-Earth Space, Quantitative measurements with wide-beam · riometers, J. Atmos. Solar-Terr. Phys., 64, 359- www.iwf.oeaw.ac.at/fileadmin/ar/ar02.pdf
Thanks again, I appreciate you help. However as I said its only background information. A little information about widebeam riometers, but nothing on its hardware analogue design. There are a few links on design, but the are restricted on few websites.
