Two DC DC with one Regulator
engr_joni_ee
Advanced Member level 3
I am working on a new board design in which I only have +5 V available as input power supply with sufficient input power supply current. I also need to have -5 V on the same board because I need to power an operational amplifier which require both +5 V and -5 V in addition to some other chips that also requiring -5 V on the same board.
I am thinking of using a step up or a boost DC DC converter which can accept +5 V as input and convert to higher voltages. I found TMH-0512D which output +/- 12 V with relatively lower maximum current +/- 83 mA. If I use a negative linear regulator after the DC DC converter then I can get -5 V output with -12 V input.
Here is the link to DC DC converter TMH-0512D.
I have roughly estimated the maximum current I need on -5 V and found that it would be between -120 mA to -150 mA. Even if I use the negative linear regulator with maximum output current -200 mA, I don't think it will be able to deliver between -120 mA to -150 mA with only one DC DC converter TMH-0512D because of limited output current +/- 83 mA.
Therefore, I am thinking how about using two DC DC converter TMH-0512D in parallel, each with maximum current +/- 83 mA and connect the output of both DC DC converter TMH-0512D to the input of a negative linear regulator that could then deliver between -120 mA to -150 mA.
I am not sure if practically it is possible or not. Kindly give your suggestions. Thanks in advance.
I wouldn't do it, especially without knowing the internals of the DC-DC. Why don't you just find a suitable DC-DC instead of trying to make two of the wrong ones work? Just look, they're out there.
This would do it:
AM1DS-0505DH30LPZ
On second thought, why do you even need a dual output DCDC. Your idea seems like an attempt to use as many parts as possible instead of just one.
All you need is 5v in to -5v out. You could get a DCDC or switching regulator.
Yes.
Another consideration. It's cheaper and more efficient to use separate non-isolated boost and inverting switchers instead of isolated DC/DC module.
With vin = 5v and vout = -5v you could use a simple Cuk Converter. (Coupled or uncoupled). Just use a cheap current mode controller, and some simple circuit to feed back the neg divider voltage to the positive referenced controller.
Seems to me that
1) dead-match between pos and neg split supplies is seldom expected and even if so, should never be assumed. Unless you have it in writing.
2) an off the shelf D -DC making split rails is almost always "cross-regulating" with one actually regulated and the rest, "as close as I*R lets it".
So
3) Why not just an inverting CMOS charge pump, if your current demand is modest?
Parallel a bunch and outphase them if you want more.
I don´t understand your idea:
* why using DUAL output converter?
* why using a 12V one ... while you need 5V
Klaus
If parallel operation not called out in datasheet you would have to contact vendor to see
if they will do it. "Normally" one sees a sense pin to allow circuitry to control sharing
current.
Write your reply...
LaTeX Commands Quick-Menu:
