Two color LED
Djsarkar
Member level 3
Member level 3
I am looking help to understand following code because I do not understand programming for Arduino
I have PIC18F45K80. I am using MPLABX 5.40 and XC8 2.30.
// Arduino test code:
int redpin = 11; // select the pin for the red LED
int bluepin = 10; // select the pin for the blueLED
int val;
void setup () {
  pinMode (redpin, OUTPUT);
  pinMode (bluepin, OUTPUT);
  Serial.begin (9600);
void loop () {
 for(val=255;val>0;val--) {
   analogWrite (11, val);
   analogWrite (10, 255 - val);
   delay(5);
 for(val=255;val<255;val++) {
   delay(5);
There are two Reverse for loop in code
What's the meaning of following two line in code?
lucky me. I have internet. And an internet search.
I simply input "arduino analogwrite" and get a lot of useful results.
Best is: a link to the original arduino reference.
Try it.
I assume it will work for you, too.
Klaus
