z543g
Junior Member level 1
_delay_ms iar
SAA1064 & TV-tuner CODE.
use 's iar c comiler. you have't help.
successful !!!! good c source function.
* i2c-bus function.
void i2c_start();
void i2c_stop();
int i2c_clock();
int i2c_ack();
int i2c_read();
int i2c_write(char data);
* saa1064 function
void disp_led(unsigned int index,unsigned char count);
* tv-tuner (tsa5520) function
void tuner(unsigned int band,unsigned char count);
/* bs1 output -- ch2~5 */
/* bs2 output -- ch6~20 */
/* bs3 output -- ch21~40 */
/* bs4 output -- ch41~69 */
possible cable function.
* t_cp,t_plus,t_minus function
void key_in();
* video decoder function ( use cable)
void v_decoder(unsigned char val1,unsigned char val2);
ha! ha! ha! ha! end.....
* i2c-bus function.
void i2c_start();
void i2c_stop();
int i2c_clock();
int i2c_ack();
int i2c_read();
* saa1064 function
void key_in();
