rrrRbert
I'm facing an interesting situation with an existing wire which I want to (ab)use as a dipole antenna for 433Mhz.
My idea is to cut the (long >10m) wire and first bring both ends(different unknown lenghts) into resonance with T1 and T2 and secondly use a balun B to feed a 50Ohm coax.
Can you share your thoughts how to approach this and which tuning(T1, T2) and balun(B) ciruits to use?
