Turkish charecters in C++
adamahmet
Newbie level 6
Newbie level 6
I use Visual c++6.0 with windows xp servicepack1(Turkish version). I want to show Turkish charecters on the screen. How can I fix this problem?
Where are you printing your text? Are you using winform? console window?
Dostum nereye nasıl yazdırıyorsun da türkçe karakterler çıkmıyor ?
I currently use VC++ .Net and everything is O.K.
If you make API/MFC application, there shouldn't be any problem.
i use cout for printing the text. and i make console application or win application without MFC.
You must firstly convert characters in text that you want to print to OEM-defined character set. You can do this transformation by using CharToOEM Windows API.
BOOL CharToOem(
    LPCTSTR lpszSrc,	// pointer to string to translate
    LPSTR lpszDst 	// pointer to translated string
