Terminator3
Advanced Member level 3
Oscillator consist of few multiplication and amplification stages. Can tuning be done this way? :
1. put schottky mixer + single diode DSB modulator at each stage output (all microstrip air coupled)
2. output from stage comes to DSB diode and modulated using constant amplitude low frequency waveform
3. output from stage mixed with modulated output from stage, get IF
4. measure amplitude of IF for each stage, tune stage for maximum IF amplitude
In other words, we use each stage output as LO signal source, modulate it and mix back with itself. I think that with bigger LO we get bigger mixing IF. Because modulation waveform amplitude is constant, it does not affect measurement. Because all elements are microstrip air coupled, waveform DC will not affect amplitude measurement.
If we use geterodine with some LO, the bigger amplitude of LO, the better mixing we get, right?
I hope it can be done, if not tell me why..
