tune out a wideband balun?
analog_chip
Full Member level 1
I am trying to implement a wideband balun as an intermediate stage in a CMOS receiver.
I want to have Real(Zin)=Rload where Zin is input impedance looking to primary when secondary has a load Rload in 1:1 balun with l1=l2=1nH and k=1 . (ideal)
Is it necessary to tune out the inductors of the balun? I yes then it becomes a narrowband system.
If I dont tune then Zin, Real (Zin) becomes inductive and has very low real part.
How to get wideband balun then? I have heard transformers can give wider bandwidth then L match. How?
A wideband balun can be only implemented by a transformer, either transmission line or conventional type.
The original question is however very vague, talking about "1 nH" balun (transformer with 1 nH inductance?) without telling a frequency range. 1 nH inductance will be too low even for GHz frequencies without a resonant circuit.
Hi vfone & FvM,
Thank you very much!
FvM: I basically want 180 phase shift between two points over frequency range 10MHz to 2.5GHz without active devices. I am planning to use a 1: 1 transformer. The 1nH thing is a model I was playing with. I appreciate any suggestions you might have.
"1 nH inductance will be too low even for GHz frequencies without a resonant circuit."
Is it too low because Zin will be very low?
10 MHz to 2.5 GHz is ambitious. Some Mini-Circuits transformers cover the range, e.g. TC1-1-13M as 1:1 balun. **broken link removed**
Hi FvM,
I am taking about onchip transformer in a CMOS process. Is it possible to have one? Its also OK for me if I can simultaneously have narrowband (tuned out) matching in 10MHz and 2400MHz. Is it possible to design a tuned transformer which is tuned at two frequencies i.e. 10MHz and 2400MHz?
It's just impossible to make transformers for the low MHz range without a core, nor the inductor values required for a lumped balun. Simply forget about on-chip impedance matching or balun for the low MHz range. Active circuits are the only option.
