TTL to RS485 and RS485 to RS232 Converter
caniget
Newbie level 5
Newbie level 5
ttl-to-rs 485 converter
Hi all,
I m in need of designing the RS485 which should be connected with micro controller, and i should transfer that converted data into PC. For that i have to design
a RS232 converter from rs485 input. anyone can please give me the idea while designing rs485 by using MAX485 IC.
Thanks,
Ragu.
ttl to rs485
firtsly you must to use max232 and rs232 to converter rs485
max232 connect to microcontroller than convert rs485
download pdf.
it may be halp you:)
Reactions: milan33
    caniget
    milan33
i m using 75176 for rs485 modbus, i want to connect more than 32 connection can any any one suggest another ic.
What about LTC2850/51&52 pls?
Up to 256 nodes on the bus...
K.
