Blind spot detection system uses either Ultrasonic or Short Range RADAR for detecting other vehicles. No IR is used.
TSOP1738 will only detect IR waves modulated at 38 kHz from IR source.
For vehicle detection it's really difficult to plonk the IR source and detect it using IR Receiver since it has very sharp
LOS.
Read what I post to better understand.
You are free to tell that to world manufacturers of cars.
Mate I told about real time blind spot detection system that are being currently deployed in automobiles.
Now you can use TSOP1738, "if & only if" the vehicle is transmitting IR waves of 38kHz. But its NOT ADVISABLE TO USE IR because, it gets lots of interference from sun light (as it also contains IR Radiations) & also from humans (yes, they do emit small amounts if IR)
So, just see what your pplication is, & decide accordingly.
