Disha Karnataki
Full Member level 5
here is the circuit how i have connected https://www.edaboard.com/threads/275615/
except connecting pin 3 o/p to the microcontroller.
when i checked the voltage @ the o/p (pin 3) i got 4.89v(almost equal to supply voltage).
then when i pressed a remote control button in front of it then to the voltage fluctuated between 4.5v(after button pressed) & 4.89v(after button released).
Is it that the ir signals are coming at such a fast rate that i am unable to see the volatge going to zero! or what is it?
then,
i connected simply ir led in front of it & then too there was no voltage variation in the o/p pin of TSOP1738.
what is wrong or it's actually ok & i can connect it to the interrupt pin of microcontroller?
then,
