TSC (Timer Stamp Counter) ?= Counter
davyzhu
Advanced Member level 1
oriental
Hello all,
Is the TSC (Timer Stamp Counter) equal to normal Counter(only have a count up register and a reference register). The year/month/day/hour/minute/second/ms function is realized by TSC hardware or OS software?
How about the Linux's tick value, 1us or 1ms? And how to send the tick to the CPU, through a interrupt or others?
Can you give me some reference on this subject. Thanks!
DAVY
The time-stamp counter keeps an accurate count of every cycle that occurs on the processor. The Intel time-stamp counter is a 64-bit MSR (model specific register) that is incremented every clock cycle. On reset, the time-stamp counter is set to zero.
To access this counter, programmers can use the RDTSC (Read Time-Stamp Counter) instruction. This instruction loads the high-order 32 bits of the register into EDX, and the low-order 32 bits into EAX.
Time-stamp counter measures "cycles" and not "time". For example, two hundred million cycles on a 200 MHz processor is equivalent to one second of real time, while the same number of cycles on a 400 MHz processor is only one-half second of real time. Thus, comparing cycle counts only makes sense on processors of the same speed. To compare processors of different speeds, the cycle counts should be converted into time units, where:
# seconds = # cycles / frequency
Note: frequency is given in Hz, where: 1,000,000 Hz = 1 MHz
This means that the year/month/day/hour/minute/second/ms function has to be realized by software..
