TS 555 CN 50 duty cycle problem
boylesg
Epping, Victoria, Australia
Can any body tell me what I have done wrong with this circuit - I just cant see it.
I am trying to implement this circuit.
Here it is on my bread board. The transistor circuit is not connected atm. R1 = 100k as per above schematic. R2 is a 10k trimpot. C1 = 10nF
But I am getting a steady 5V out of pin 3 - no oscillation whatever.
what does the red wire on pin5 do? It´s not according the schematic.
Klaus
More than once I've hooked together a 555 pulse generator (hardware) and I saw constant supply voltage on the oscilloscope. When in truth it was about 99 percent duty cycle! Low state lasted so briefly it didn't appear onscreen at first until I adjusted a few dials.
By applying various volt levels to pin 5 (Ctl pin), I change duty cycle. The 555 is constructed to do that. Yet most designs just put a capacitor to ground.
