samuelr
Member level 4
Having a bit of a problem trying to switch on my SCR, I have hooked it to a 380VAC source and used the following schematic
https://www.tablix.org/~avian/blog/images2/2011/03/scr_trigger_using_an_optoisolator-t.jpg
It works fine on a lower votlage but when its going into a 380VAC it turns on by itself without me triggering the opto coupler. I changed the resistor to a 47kohm instead of the original 470ohm.
