ErikG
Hello all,
I am trying to verify if me theoretical predictions for a low pass filter match the real world attenuation.
My setup is a function generator, outputting a sine wave at 1Vpp, which with no load is really 2Vpp.
The generator is connected to the input of my low pass filter. Just a simple RC circuit with a 68 Ohm resistor and a 1.3uF cap to ground.
The load on the output is matched to the 50 ohm series resistance in the function generator.
When the LPF is connected to the function generator, the output gets loaded down a little bit. In this case its about .3v so the output is 1.7v
My question is this:
Should i use my unloaded voltage to calculate attenuation or the loaded voltage to figure out the attenuation in the circuit?
IE 20*log(1.7Vpp/output of LPF)
or the unloaded output of the function generator
IE 20*log(2Vpp/output of LPF)
Thanks for your help.
-ErikG
-ErikG
