maark6000
Member level 5
I'm trying to advance a SN74LS191N binary counter manually. I've got the circuit working beautifully with a 555 timer, it advances the counters (I have two cascaded together to make 8-bit) by placing the timer's output into the CLK inputs. No problems there. But I also want to be able to advance the counters manually using a push button. When I try this, the counter acts very weird. It tends to skip numbers, it'll go backwards, forwards, sometimes huge jumps forward... very strange behavior. At first I thought was having switch bounce issues. I actually hunted down some 7414's to make an RC switch debouncing circuit, I've looked at my manual clock waveform on the scope and it's perfect... no bounce. But still, the counters are going nuts. Any idea where I've gone wrong?
Thanks in advance...
Mark J.
Mark J.
