jaydag71
Newbie level 6
![Newbie level 6](/styles/images/ranks/blevel3.gif)
I am trying to identify a FET or perhaps transistor that is used in the Eflite Blade mcx 5-in-1 controller. I fried mine the other day and want to see about finding a replacement set for future use and possibly to repair the one I damaged,, thouh I suspect it is useless as the pcb is fried and a trace lifted also...
all by itself!
This part is giving me a headache to find in conventional searches and common smd parts lists,, but am hoping one of the board gurus will have a more complete database or listing that they are keeping stashed away for just such refs?
This part is in sot-23 package I believe with a code as follows: ADUE16 ,, the AD are underlined, the U has a dot above, and the number 16 is running vertical and small beside the E.
As mentioned, I have had no luck searching for this code! The 5-in-1 is a rf receiver, mixer, gyro, etc all on one tiny pcb. The thing runs off single cell lipo and has a low voltage cut-off. The motors these fets are running are not much larger than pager motors- they are small, likely types used in regular small servos perhaps- anyways I am wondering if I cannot find the exact part then maybe finding some similar ones based on what power specs I can manage to find out?
Any help much appreciated! I hope I posted in right area!
