arbj2
Full Member level 3
I am trying to drive a coreless DC motor (used in RC planes), for this I use a NPN transistor, with base connected through a 4.7K resistance, the collector is connected to one end of the motor and the other end is connected to +4.7V (motor supply). Emitter is connected to ground
When the resistance is made high, for some reason the motor does not run at full speed, the current drawn is only 110 mA.
How can i make the motor run at full speed ? When the motor is directly connected to the +4.7V supply, the current drawn is 600 mA.
The basic idea is to use a micro-controller, with PWM output to control the speed of the motor.
thanks
a
thanks
a
