BojackHorseman
Newbie level 6
I am trying to build a Binary to BCD converter using the double dabble algorithm.
I wrote the code for the same and when I simulated the entire thing it was observed that my if statement is not getting executed properly.
The testbench is given below.
The output I am expecting is
Can someone please help me in debugging this problem? I have been stuck here for a long time.
`timescale 1ns / 1ps
module test_6( input [13:0] bin ,
output reg [3:0] ones, // ones value of the input number
output reg [3:0] tens, // tens value of the input number
output reg [3:0] hundreds, // hundreds value of the input nnumber
output reg [3:0] thousands // thousands value of the input number
integer i;
reg [15:0] scratch; // 16 bit register
reg [29:0] combined; // 30 bit concatenated register bin and scratch
always @(bin) begin
scratch = 0;
combined = {scratch[15:0], bin[13:0]}; // concatenating scratch and bin into combined
for (i=0; i<14; i=i+1) begin
combined = combined<<1; // left shift by 1
if (combined[17:14] > 4) begin
combined[17:14] = combined[17:14] + 4'b0011; //check if >4, if yes add 3
$display("ones = ",combined[17:14]);
end
if (combined[21:18] > 4) begin
combined[21:18] = combined[21:18] + 4'b0011; //check if >4, if yes add 3
$display("tens = ",combined[21:18]);
end
if (combined[25:22] > 4) begin
combined[25:22] = combined[25:22] + 4'b0011; //check if >4, if yes add 3
$display("hundreds = ",combined[25:22]);
end
if (combined[29:26] > 4) begin
combined[29:26] = combined[29:26] + 4'b0011; //check if >4, if yes add 3
$display("thousands = ",combined[29:26]);
end
end
thousands = combined[29:26];
hundreds = combined[25:22];
tens = combined[21:18];
ones = combined[17:14];
$display(ones);
$display(tens);
$display(hundreds);
$display(thousands);
end
endmodule
module test_6_tb;
// Inputs
reg [13:0] bin;
// Outputs
wire [3:0] ones;
wire [3:0] tens;
wire [3:0] hundreds;
wire [3:0] thousands;
// Instantiate the Unit Under Test (UUT)
test_6 uut (
.bin(bin),
.ones(ones),
.tens(tens),
.hundreds(hundreds),
.thousands(thousands)
initial begin
// Initialize Inputs
bin = 14'd25;
// Wait 100 ns for global reset to finish
#100;
// Add stimulus here
end
endmodule
But as you can see in the attached image it is not doing as such.Thousands should have the value 1,
hundreds should have the value 1,
tens should have the value 5,
ones should have the value 7.
