MSMorkan
Newbie level 2
Hello Everyone,
I am trying to drive LEDs which requires 2.9V forward voltage and 1A current.
Currently circuits have 4 LEDs in series and have various of channels. I can change the LEDs to 3 in series if needed but channel will be increased as well.
4LEDs x 4 (4 AMPS), 4LEDs x 8(8AMPS) and 4LEDs x 16(16AMPS). I need to build a common PCB for all of them but components on them may vary.
Now, I use Meanwell LDD-1000L 1A constant current for each channel (Vin must be higher than Vout). It costs too much (3.6-4$ for each LDD-1000L) and also I cannot fit them in the case. I need to design my own 1A (for each channel) constant current power supply. But I am stuck at choosing the right integrated device.
This is the case for 12V vehicle battery which has a voltage around 12-14.5V
For 24V vehicle battery: I convert 8LEDs in series and reduce channel to half by soldering 0 ohm resistors to my PCB. In this case I use half of constant current sources but still cost is too much and still occupies a lot of space.
I am open to any advices about replacing LDD-1000L with custom design PCB.
My first thought is using a 1.5A DC-DC buck converter circuit + current limiting resistor for each channel.
Also I have another question for this one. What happens if I connect 2 or more parallel DC-DC buck convertors and draw 2 or more ampers from them instead of using higher current rated DC-DC buck converter? Is it harmful for short/long-term usage?
Thanks a lot
Have a nice day
and Sorry for my bad English :-(
>M.Suat
Thanks a lot
Have a nice day
>M.Suat
