True RMS measurement - how to do it?
techie
Advanced Member level 3
Pakistan
How to measure the True RMS voltage and current of 50/60Hz mains (sine wave with harmonics) using a successive approximation ADC and a microcontroller. What is the sampling rate required, ADC resolution, computation involved and technique used.
thanks for any suggestions
There was an article in circuit cellular:
hxxp://www.chipcenter.com/circuitcellar/november99/c119dp1.htm
sourcecode can be found here:
fxp://ftp.circuitcellar.com/pub/Circuit_Cellar/CConline/1999/Nov99/Perkins.zip
best regards
AD536 from analog devices may help you.
The AD7754 seems the best suited IC for this purpose. Thanks for pointing that out. This IC has all the front end required for the purpose, a PGA, an ADC and rms convertions etc. great design
Re: True RMS measurement
the True RMS chips are available at the market but all of them are expensive. you can realized this with a MCU.
if you want to work at 50-60 Hz you should sample the signal at the 100-120 Hz. but these restricts are theorical. I realized this projects at speaking frequency with Cypress PSoc.(www.cypressmicro.com) and in my opinion you should sample the signal at least 200 Hz. (for 50 Hz.) and sample count should be 128 at least.
the RMS calculation C sample code is below
total = 0;
for (i=0; i<SMP_CNT; i++)
total += (sample*sample);
}//for
RMS = sqrt(total / SMP_CNT);
you can use this code as you want.
tmk :wink:
:eek: hi tmk, I just saw your post and I have some related question to ask you.
total = 0;
}//for
I'm going to do a PIC project and this is the link to my project:
Do you have the C code for the frequency, peak-to-peak, average, and duty cycle calculations of an analogue waveforms.
My project is also going to measure these values for an analogue waveforms 50/60Hz mains using an ADC (TLC 548 8-bit resolution) and a PIC 16F628. What is the sampling rate required? ADC resolution? computation involved and technique used? Is it same as what you have said?
