simon_12
Junior Member level 3
Hi all
The output voltage of my UPS is approx 300 volts. I have also checked the transistors, they are working properly. When the battery is charging , through main supply, the output voltage is upto the normal value that is 220 volts, but as soon as the main supply fails and the UPS starts , the output voltage becomes 300 volts. Can anyone pls tell me what is the PROBLEM
regards
regards
