Troubleshoot arm-elf-gcc compiler
subdural
Junior Member level 1
Neutral Zone
arm-elf-gcc hello world
Hi All,
I'm newbie. I need your expertise advice on troubleshooting arm-elf-gcc on cygwin.
a) I installed the cygwin setup (full installation)
b) I installed the gnuarm toochain v4.0.0 for cygwin (windows)
I wrote the simple C program (hello world) and compile the program on gcc at cygwin is succeded ant got out put "HELLO WORLD"
main()
printf ("Hello World!\n");
but when I compile using arm-elf-gcc compile on cygwin I got this message
$ arm-elf-gcc hello.c
hello.c: In function 'main':
hello.c:3: warning: incompatible implicit declaration of built-in function 'printf'
HOWEVER using gcc is successful
$ gcc hello.c
$ gcc hello.c -o hello.exe
$ hello.exe
Hello World!
Kindly please help me
thanks
[/img]
did u include the required inlude files ????
its will be better if u use a make file ..
try this makefile...
Sample Hello World Compile
# cat Makefile
CC = /opt/tools/bin/arm-elf-gcc
# this is the method that worked here
CFLAGS= -D__PIC__ --fpic -msingle-pic-base
LDFLAGS= -Wl,-elf2flt
# another method, I think I missed zFLAT executables on kernel
#CFLAGS=
#LDFLAGS= -Wl,-elf2flt=-z
# a third method I found
#CFLAGS = -O2 -pipe -Wall -g -fpic
#LDFLAGS = -Wl,-elf2flt
LIBS =
OBJS = hello.o
all: hello
hello: $(OBJS)
$(CC) $(CFLAGS) $(LDFLAGS) -o hello $(OBJS) $(LIBS)
clean:
rm -rf *.o *.elf *.gdb hello
# eof Makefile
# cat hello.c
#include
main(void){
printf("Hello world!\n");
exit(0);
put it on NFS and run it from unit
# ./hello
Hello world!
hope i helped u
helios
    subdural
simple hello world cygwin arm
u must use a make file
# cat Makefile
#CFLAGS=
LIBS =
OBJS = hello.o
all: hello
hello: $(OBJS)
clean:
# eof Makefile
# cat hello.c
#include
main(void){
exit(0);
# ./hello
Hello world!
hope i helped u
helios
    subdural
