DistrictJP
Newbie level 2
Greetings. I've been working on a Vinotemp TEDS28 wine cooler, which I use as a humidor. This weekend I replaced the peltier (I have also replaced the controller board) and the strangest thing is happening.
It's like the temperature sensor is right on the cold-side fins. At first I had the peltier in backwards. I matched wire colors as well as facing the side with letter the same as the one I removed, but almost instantly after turning it on the temp readout shot up to 81+ and the fins were definitely hot. After getting that turned around, now the temp gauge shoots down to 54. The cold fins are definitely cold but since the Vino thinks it is 54 inside it turns off the fans, and there is no change in internal temp.
Any ideas here? I can patch the connector pins to a breadboard and an arduino but am not proficient enough with electronics to be sure I wouldn't blow anything up. How could I go about using the arduino to send the signals to turn on and off the cooling in response to a different sensor, and a different readout?
I basically am asking how to leverage all the existing cooling electronics - can it be as simple as learning how to send the right signals to the control board on the Vinotemp?
Any advice is greatly appreciated. This is as much a learning project as it is for practical use.
jp
jp
