[SOLVED] Trouble Selecting Electrical Connections and Wires in Virtuoso Layout XL
SaFo
Newbie
Newbie level 2
Hello,
When using the Virtuoso Layout XL Editing Window in Cadence for layout creation, I can easily select and move transistors as needed. However, I encounter challenges with electrical connections, specifically wires. I am unable to select them, and as a result, I cannot edit them. Could you please provide guidance on resolving this issue?
Thank you.
Layers set to valid and selectable?
Objects you can see, may not be "at present level" of
the hierarchy; try switch-edit or edit-in-place to dig in.
