Trouble Instantiating a Module with a Parameter
kvn0smnsn
Junior Member level 2
I wrote a couple of Verilog modules, one a generic multiplexer with parameter (nmBits) passed into it and the other that instantiates it with value 2, and included those two modules in file "UmM.v":
module Mux #( nmBits = 1)
           ( result, control, hgVal, lwVal);
  output [ nmBits-1:0] result;
  input                control;
  input  [ nmBits-1:0] hgVal;
  input  [ nmBits-1:0] lwVal;
  genvar bt;
  generate
    for (bt = 0; bt < nmBits; bt = bt + 1)
    begin
      assign result[ bt] = control ? hgVal[ bt] : lwVal[ bt];
    end
  endgenerate
endmodule
module UseMux( rslt, cntrl, hVal, lVal);
  output [ 1:0] rslt;
  input         cntrl;
  input  [ 1:0] hVal;
  input  [ 1:0] lVal;
  Mux mx2 #(2)( rslt, cntrl, hVal, lVal);
endmodule
Then I wrote a module to test it and put both files into EDA Playground. When I clicked on <Run>, I got told:
Parsing design file 'design.sv'
Error-[UTOPN] Unknown type or port name
  The type name 'Mux' is unknown, or the identifier 'mx2' has not been listed
  as a port, or the declaration might represent an instance missing
  parentheses.
  "design.sv", 24
  Source info:   Mux mx2 #(2)( rslt, cntrl, hVal, lVal);
Error-[SE] Syntax error
  Following verilog source has syntax error :
  "design.sv", 24
2 errors
CPU time: .173 seconds to compile
Exit code expected: 0, received: 1
Done
Can anyone tell me what I'm doing wrong? Why won't this compile?
