Trouble converting 10.5 to 7.2
bigcountry350
Newbie level 1
Newbie level 1
dsm0006
Hi all,
I've been searching the internet and some message boards, but haven't found anything specific to my problem. I did find a similar problem converting 9.2 and 7.2 to 7.0, but I don't believe it is applicable to my situation.
This is my problem:
I'm trying to save a file in Orcad CIS 10.5 to the 7.2 format. However, when I do this it gives me a DSM0006 error, and says that the file cannot be found. If I save it with the current filename, it also delete the DSN file! I know that this problem is specific to this design, because I succesfully saved another design to the 7.2 format after this error occured.
Also, when I close Orcad after this error, I received another error from orcad called an EXCEPTION_ACCESS_VIOLATION
I found a posting on another board about converting 9.2 and 7.2 to 7.0, and it said that if you are using certain aliases for the same part it will give you the DSM0006 error. I have checked my part names in this design with another design that converts to 7.2, and I don't see anything that is used in this design, but not the one that converts. Does anyone have any ideas?
Thanks
