Nobody here told you to replace the 100pF (101) capacitor with a 1000pF (102) capacitor because they are not close.I have seen many times where person dont have a specific part and a persons here tell them to use something close enough I even got the same advice here
No they are not close. 101 is 10 with ONE zero at the right end making it 100pF. 102 is 10 with TWO zeros at the right end making it 1000pF (1nF). 103 is 10nF, 104 is 100nF and 105 is 1uF.If I was to use a capacitor which is 101 and I found a 102 which is have to be the closest
I explained that it will cut high audio frequencies and cause distortion of high frequencies to be high.explain why in this case that replacement wont work.
its just this other guy "betwixt " replying by saying something that makes no sence to my topic.
so you missed (guess) 6 transistors and 6 resistors out of the design and the two you did fit were the wrong types.I didnt add all the transistors I only added a pair for testing I used 2SC3856 and 2sa1216
Did you notice their voltage ratings are significantly lower than BC546 and in fact less than the amplifier supply voltage?I used bc547 I didn't have any bc546
The component values are for +/- 56V as shown on the schematic.I supplied the board with 40v +/-
'102' is ten times bigger in value than '101' but as Audioguru pointed out, it should almost certainly be 100uF not 100pF anyway. (1,000,000 times bigger!)I think c5 is 100pf and I used a 102 because I didn't have a 101
-->The change of diodes is less of an error
It depends. If he used ONE 4007 (1000V) instead of TWO 4004 (400V) (because of the increased voltage rating) then it surely makes a difference.and also the 2 1n4004 in series with the 3.3k resistors I used 1n4007 instead
I etched this circuit also I used photoshop and saved it back to Jpeg and it actually attacked 2 transistor legs up on saving the file, not until I etched the board and assembled the parts I realized that it did that some how.
Klaus
Best is to use the same parts like in the schematic.So should I use only a single 1n4007 and then use a jumper to make the other section of the circuit remember its a pcb.
Are your answers in this post a joke?I too learnt the stuff the hard way:
It is the frequency compensation capacitor used in all opamps and audio amplifiers. It is the most important capacitor in the circuit because it prevents the amplifier from oscillating at the high frequency where phase shifts in the amplifier cause high frequency negative feedback to become positive feedback. Without the 100pF capacitor then the amplifier has some voltage gain at the oscillation frequency but with the capacitor its gain is less than one at that high frequency so it does not oscillate.100 pF is way too small, can't we just ignore it?
Two diodes are used to set the bias in the output transistors to class-AB. With only one diode then they would be biased in class-B that produces horrible crossover distortion. The diodes are never reverse biased so their maximum rated voltage does not matter.The fellow must have put two diodes in series because he was not having one with high reverse voltage.
I don't use god, instead I use experience. On a sound system website, Elliot Sound Products, I found an identical amplifier circuit with the same supply voltages, the same 100uF and 100pF capacitors, the same two diodes and many resistor values the same. Its transistors were different.Only god can tell when a 100 means 100 uF and when another 100 means 100 pF.
No and no. The circuit uses ordinary power transistors. The TIP135 and TIP136 are DARLINGTON dual transistors which are COMPLETELY DIFFERENT and will not work properly. It is common sense to compare replacements on their datasheets.on the output I only used 1 pair which I stated, I actually have TIP135 and TIP136 ..... The transistors I used was also a recommendation from the guy I got the schematic from even though he didnt use them himself ..... I applied a little common sense to what I was doing.
Because they were very different to what is needed then they did not work properly.I didnt use a heatsink on the Pair of transistors I used and with that test they didnt get warm.
No. With the darlington transistors you used then 4 diodes are needed. Look up "crossover distortion" that I talked about in this post.So should I use only a single 1n4007 and then use a jumper to make the other section of the circuit?
Maybe unusual, but the LED has it's benefit: A LED creates less noise than a typical zener.The LED constant current is unusual in an audio amplifier to say the least
