cupoftea
Advanced Member level 6
Doing 50:1 Current sense transformer for UCC28070A Boost PFC. Each Booster is 1kW. For secondary, choice is between 50 turns of TEX-E 0.2mm, or 50 turns of 0.4mm Enamelled copper wire. Both are pretty much same in outer diameter.
Would you agree that the TEX-E is preferable, since with the insulator jacket around it, the interwinding capacitance will be less, and the reset of the CST will be more effective?
In UCC28070A Boost PFC, the CST is set up in unidirectional mode. (The CST is in series with the drain of the FET, and incidentally, the “downstroke” is estimated by the UCC28070A)
TEX-E triple insulated wire.
https://www.furukawa.co.jp/tex-e/en/product/texe_series.html
UCC28070A
UCC28070A
