Js_Ong
Member level 4
Hi All,
I am controlling 5 valves operation using 8051 with a 12V/5V power supply, it works well to control all the 5 valves I need. At the same time there is a weighing system will turn ON and OFF 6th valve by it's relay. Problem happened when both system operate together.
When the relay at the weighing system triggered the 6th valve, it makes like a short circuit to my 8051 board and completely my 8051 was not functioning anymore. This happen when I use the same 12V supply to all the valves.
I change and make another separate power supply just for the weighing system the 6th valve, it is better but still sometimes it gives a false signal to my 8051 system, at least my 8051 can still operate with next step operation.
I am wondering why this happened when the relay triggered? I can say they are two separate system that electrically are not connected to each other. How to solve this?
