trigonometric functions in mikro C pic compiler problem
Noman Yousaf
Full Member level 4
Full Member level 4
Lahore Pakistan
hi
i want to perform some trigonometric functions in mikroC like get the value of sin90, cos30 etc.
i wrote this code but when i run it and watch RAM, values are not correct.
even when i do it with float, incorrect values occur.
please help
Code C - [expand]
8
9
10
11
12
13
14
15
long val3;
void calculate (void)
val3=sin(90);
void main()
while(1)
calculate();
It is expected an argument in radians, not in degrees.
You must multiply it by a factor of ( 2*PI / 360 ).
it shows in RAM is 8.5090 ok?
when it is multiplied to 2*pi/360 (0.01744), answer is 0.1483
where as its answer must be 0.707
can anyone tell the simplest way to get sin value in degrees?
what does mean by the following?
i got it from help
sin
Prototype
double sin(double f);
Description Function returns the sine of f in radians. The return value is from -1 to 1.
Example doub = sin(PI/2.); // doub = 1.000000
how can i use it for my purpose?
please help
You're having some mistake:
  • 45*( 2*pi/360 ) = 0,785
  • sin ( 0,785 ) = 0,7068... [ operation in rads ]
