DatsAbk
Member level 3
Hello ,
I have used optoisolator MOC3041 and triac BTA41-600BWG for switching a 2500W load.
The circuit is as below:
The triac heats up upto 117 degree Celcius which forces the circuit to get latched and remain ON forever.The traic burns up at around 130 degrees which is obvious.But the current flowing is actually just 9.7A with 230V AC supply.
Why is the circuit heating up?
What is the solution?
In the circuits given in several application notes the resistor Ra1 across gate and A1 terminal is not given but once I tried the same circuit which didnt work so I added the resistor and the switch worked well but its heating up.Does the resistor affect??
I believe there is some basic misunderstanding in my circuit but I'm unable to find it...:-(
Please help.
Thankyou in advance
Please help.
Thankyou in advance
