Triac controlling using uC
varunme
Advanced Member level 3
can i control the below triac board using uC?
Is it by making the 12V on/off ?
Hello ,
looks like the 12V input is the control input of the board , so i believe your assumption is correct
and in this case you can control with with a uC by controlling a relay that connect 12 VDC
Regards
Reactions: varunme
    varunme
Yes you can. Just pay attention on triac dissipation and temperature, because there is no heatsink.
Best regards,
Peter
Reactions: varunme
    varunme
so.
i have to connect uC to mosfet and mosfet to this board 12V isnt it ?
You can even lower resistor value for optotriac diode and use 5V instead 12V.
Transistor drive optotriac:
Best regards,
Peter
Reactions: varunme
    varunme
The resistor value for optotriac diode in my board is 220R, to what value should i lower ?
yes,
after some calculations,
i didnt modified anything
i connected the 12V directly
it worked !!!
Why would you need the transistor? You could directly drive the opto LED from your microcontroller.
