transmitting and receiving data from usart by using PIC18F4520
naveenkr37
Newbie level 1
I am having a problem in receiving continuous data from USART by using PIC18F4520. I am receiving single character or integer, but i am not receiving correctly strings or continuous integers
here is my code,
"USART TRANSMITTING PROGRAM"
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
#include <p18f4520.h>
#include "usart.h"
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
#pragma config PBADEN = OFF
#define TXEN TXSTAbits.TXEN
#define BRGH TXSTAbits.BRGH
#define SPEN RCSTAbits.SPEN
#define CREN RCSTAbits.CREN
#define BRG16 BAUDCONbits.BRG16
#define TXIF PIR1bits.TXIF
//#define RCIF PIR1bits.RCIF
    int str[]={'0','0','0','0','0'};
    int i=4,j=0;
    int a[]={1,2,3,4,5,6},c;
void USARTInit(void);
void USARTWriteByte(char );
void USARTWriteString( char* );
void USARTWriteInt(int ,unsigned char );
void USARTInit()
    //Baud Rate = 9600 Bits per Second
    //*** Note: Valid On 20MHz Crystal ONLY ***
    //For other crystal freq calculate new values for SPBRG
    SPBRG=31;
    BRGH=0; //low speed
    BRG16=0; //for 8bit baud rate
    SPEN=1; // serial port enable
TXEN=1; // transmit enable bit
    CREN=1; //Enable Receiver (RX)
void USARTWriteByte(char ch)
    //Wait for TXREG Buffer to become available
while(!TXIF);
    //Write data
    TXREG=ch;
void USARTWriteString( char *str)
    while((*str)!='\0')
        while(!TXIF);
        //Write data
        TXREG=(*str);
        //Next goto char
        str++;
void USARTWriteInt(int val,unsigned char field_length)
    if(val<0)
        USARTWriteByte('-');    //Write '-' sign for negative numbers.
        val=(val*(-1));             //Make it positive.
    //Convert Number To String and pump over Tx Channel.
    while(val)
        str[i]=val%10;
        val=val/10;
        i--;
    if(field_length>5)
        while(str[j]==0) j++;
    else
        j=5-field_length;
    for(i=j;i<5;i++)
        USARTWriteByte('0'+str[i]);
void main()
TRISCbits.TRISC7=1; //set RC7 to input
TRISCbits.TRISC6=0; //set RC6 to output
USARTInit();
while(1)
for(c=0;c<6;c++)
USARTWriteInt(a[c],1);
"USART RECEIVING PROGRAM"
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
#include<delays.h>
#include "lcd.h"
#include "usart.h"
void LCDStart(void);
void USARTInit()
    //Baud Rate = 57600 Bits per Second
    SPBRG=31;
    BRGH=0;
    BRG16=0;
    SPEN=1;
    CREN=1;
    //TXSTA REG
    TXEN=1;
    //RCSTA
    //BAUDCON
          //SPBRGH=0X02;
          //SPBRG=0X08;
#pragma idata section3
const unsigned char str[]="recieved data";
char a[6],i=0,c=0;
#pragma code
void main()
TRISCbits.TRISC7=1;
TRISCbits.TRISC6=1;
Wait(50);
LCDInit(LS_BLINK);
Wait(50);
USARTInit();
Wait(50);
while(1)
LCDWriteStringXY(4,0,str);
while(!RCIF);
c=RCREG;
a[i]=c;
i++;
LCDStart();
void LCDStart()
Wait(50);
LCDClear();
Wait(50);
LCDGotoXY(6,1);
while(a[i]!='\0')
LCDData(c);
i++;
i need solution for above problem
I would first recommend testing your transmission routines using a PC with terminal emulator software, like Putty, as the receiver.
You can then determine which transmission routines, if any, are not functioning as expected and then remedy the issues.
I would then test the reception routines using a PC with terminal emulator software as the transmitter.
You can then determine which reception routines, if any, are not functioning as expected and then remedy the issues.
Note: When interfacing a devices UART/USART to a PCs RS-232 port, an RS-232 transceiver, like a MAX232, must be utilized or the microcontroller maybe damaged.
Finally, perform a similar test to which you have previously posted, which tests the interaction between two devices using the appropriate routines.
I allows recommend testing individual routines, before testing their interaction between them.
BigDog
