I need to transmit a PWM signal wirelessly at 5 GHz and receive it at the other end. Could you please suggest any COTS devices available and provide any recommendations?
I read "pwm" as general digital signal. But which frequency, minimal and maximal pulse width? Required pulse width resolution and accuracy?
What's the intended RF channel? Free space, wave guide or cable? Restrictions regarding RF level and modulation bandwidth, e.g. due to radio regulations?
Latency, transmit measured digital value and reconstruct using PWM on sink side ? Or
would that latency be objectionable ? Is PWM source a baseband signal ?
