transmission using pmodrf1by 8051
cheetha
Full Member level 2
Full Member level 2
AOA
can any one help for the transmission of simple 1 byte from PmodRF1 by using 8051 i have problems in understanding its datasheet ?
thanks
AOA
thanks
Just by giving the datasheet a quick glance I noted that it uses SPI to communicate. Have you configured SPI on your microcontroller? This would be the first step. After you verify that SPI is configured correctly and that you can send out a byte onto the SPI bus, then plug in the RF module and try again. This allows us to eliminate SPI as the origin of your problem. After that, I would suggest looking at the setting of the RF module and verifying that they are configured for SPI communication and that they match what you are trying to send out via SPI.
Regards,
Willis
how to configure spi on microcontroller?
in datasheet in SPI command byte definition for frame buffer acess bit4 to bit 0 are mentioned reserved what does this means?
thanks....
thanks....
What specific microcontroller are you using?
Regards,
Willis
iam using 8051
thanks....
I would start with learning about SPI and how to configure it.
I have included a few tools to help you get started...
A very brief overview of SPI on the 8051...
http://www.dnatechindia.com/Tutorial/8051-Tutorial/Introduction-To-SPI-Interface.html
A more in-depth description of SPI (Courtesy of Wikipedia)...
http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus
An application note from Atmel that provides multiple (and very well commented) code example on how to configure SPI on the 8051...
http://www.atmel.com/Images/doc4348.pdf
Once you have browsed the articles and have gained a better understanding of SPI, start writing code to send out a byte via SPI; use the Atmel application note for help. Once you have done this, we will be able to move on and try to communicate via the RF PMOD. If you run into trouble while programming the SPI, post your code and we will be more than happy to help.
Regards,
Willis
